ileodo
Mar 30, 2020Tutor
Orbi Satellite Drop Connection time to time
Hi, For some reason, my RBS50 Orbi Satellite dropped connection couple times a day. The synptoms are: 1. all the devices conntected to RBS50 Satellite dropped the connection (both Wireless a...
ileodo
Apr 09, 2020Tutor
seem like no, I'll give it a try now, and see if any process restared on satellite.
however, as per netgear official website, it's a valid setup to have both router and satellite connected to a swtich to have ethernet backhaul.. why it doesn't work well in my case?
Apr 09, 2020Guru - Experienced User
Maybe the switch is the cause.
Seen issues with switches with IGMP protocols and green ethernet features cause problems between the RBR and RBS if one is in between them. Non managed and non green ethernet switches are prefer in between the RBR and RBS. I use HP Procurve 1400 series switches between mine.
