ileodo
Mar 30, 2020Tutor
Orbi Satellite Drop Connection time to time
Hi, For some reason, my RBS50 Orbi Satellite dropped connection couple times a day. The synptoms are: 1. all the devices conntected to RBS50 Satellite dropped the connection (both Wireless a...
theoak
Apr 09, 2020Luminary
ileodo wrote:
And here is my setup:
+-----------+ | ISP | +-----+-----+ | WAN v +-----+-----+LAN +------------+ | Router +------->+ Switch | +-----------+ +--+*----*---+ || | +------+| +------+ | +----+ | WAN v v Port1 v Port1 +------+--+--+ +------+------+ | RBR50 | | RBS50 | | AP mode | | AP mode | +------------+ +-------------+
Another option if you cannot directly connect your router to your satellite ...
If your switch is managed can you:
1. Add a line from port 1 of your Router back to your switch?
2. Via your managed switch separate the Orbi to Orbi traffic - signified by the * on the Switch.
