pugcoin
Jun 15, 2019Tutor
Orbi Satellite dropping connection regularly
Upgraded from Apple to orbi about 3 mo ago - wow! The speed increase is amazing. One downside though is my nest Hello camera loses WiFi connection pretty regularly over the last few months....every 1-...
Jun 15, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
pugcoin wrote:
Upgraded from Apple to orbi about 3 mo ago - wow! The speed increase is amazing. One downside though is my nest Hello camera loses WiFi connection pretty regularly over the last few months....every 1-2 weeks (attached is screenshots of notifications).
My question: how do I go about diagnosing how to figure out the root cause? Not sure if it’s the nest camera or the new orbi (when the nest was on the Apple WiFi I got no notifications so I suspect it’s the orbi)
