pugcoin
Jun 15, 2019Tutor
Orbi Satellite dropping connection regularly
Upgraded from Apple to orbi about 3 mo ago - wow! The speed increase is amazing. One downside though is my nest Hello camera loses WiFi connection pretty regularly over the last few months....every 1-...
richvohra
Sep 04, 2019Aspirant
Been dealing with the same problem for months and there is no solution. There are so many people with this problem and no solutions in sight.
Going to be buying Google WiFi and return the Orbi to Costco.
- FURRYe38Sep 05, 2019Guru - Experienced User
Good luck in your endeavours.
My Orbi is working just fine. So are many others.
Going to be buying Google WiFi and return the Orbi to Costco.- pugcoinSep 05, 2019TutorHi the dropping events stopped a few days after I posted. I apologize for not updating this thread.
I suspect it was the Nest Hello. I did a reset on the Nest unit and have not had any drops since.
Good luck!- richvohraSep 05, 2019AspirantThanks for the update
I will try some of the suggestions here and I hope it works
Netgear support doesn’t know what to do
I feel like people here are more knowledgeable
