pugcoin
Jun 15, 2019Tutor
Orbi Satellite dropping connection regularly
Upgraded from Apple to orbi about 3 mo ago - wow! The speed increase is amazing. One downside though is my nest Hello camera loses WiFi connection pretty regularly over the last few months....every 1-...
richvohra
Sep 04, 2019Aspirant
Been dealing with the same problem for months and there is no solution. There are so many people with this problem and no solutions in sight.
Going to be buying Google WiFi and return the Orbi to Costco.
Sep 05, 2019Guru - Experienced User
Good luck in your endeavours.
My Orbi is working just fine. So are many others.
- pugcoinSep 05, 2019TutorHi the dropping events stopped a few days after I posted. I apologize for not updating this thread.
I suspect it was the Nest Hello. I did a reset on the Nest unit and have not had any drops since.
Good luck!- richvohraSep 05, 2019AspirantThanks for the update
I will try some of the suggestions here and I hope it works
Netgear support doesn’t know what to do
I feel like people here are more knowledgeable- FURRYe38Sep 05, 2019Guru - Experienced User
Try some of the suggestions I posted.
Give feedback to the question presented so we can get an idea of how your system is all set up and placed. All feedback helps us understand what you have going on.
Can try reverting FW versions as well to see if this helps.
