dctheobald
Jan 28, 2018Tutor
Orbi Satellite dropping connection to VOIP
I have the RBR50 router and 2 RBS50 satellites - each device is on a separate floor of my 3 story house. They are close enough in proximity with each other as they do not show issues in the Orbi con...
SBell
Jan 29, 2018Guide
I had a similar problem with an Ooma VOIP box connected to an Apple Airport Extreme. It turned out I had the Ooma too close to the router and the strength of the WiFi signal was interfering with it and causing it to reboot and do all sorts of crazy stuff. Moved the Ooma a few feet away and it worked fine. Might be worth a try.
- dctheobaldJan 29, 2018Tutor
For your Ooma, was it ethernet cabled into the router? I'm curious why the device would be impacted by wifi signal if it's cabled in? I switched satellites and still had the Avaya reboot mid-call...so it doesn't seem to be a particular satellite acting poorly....
- SBellJan 29, 2018Guide
Yes, it was Ethernet cabled to the router. I never would have expected it was the issue since it was hardwired, but after I finally broke down and called Ooma support, it was one of the first things they asked about so they obviously knew it was an issue. Probably just poor shielding of the electronics in the Ooma box.
I’m not saying that’s the case with yours, but it’s an easy thing to check and rule out. But the Orbi is such a mess, it’s probably something you’re going to spend weeks troubleshooting and never get an answer. I’m having tons of internet and network drop outs with my RBK50 and 2 Satellites. Some 2.4 GHz devices won’t connect at all, streaming drops, etc. etc. The amount of time I’ve wasted trying fix various issues with this thing is ridiculous. So far the Orbi has been nothing but problems. They should really either get their firmware sorted out finally, or offer people refunds. Sorry my advice turned into an anti Orbi rant!
I've played around with some of the WAN settings tonight to turn off SIP ALG to see if this helps....
