dctheobald
Jan 28, 2018Tutor
Orbi Satellite dropping connection to VOIP
I have the RBR50 router and 2 RBS50 satellites - each device is on a separate floor of my 3 story house. They are close enough in proximity with each other as they do not show issues in the Orbi con...
dctheobald
Jan 30, 2018Tutor
I've played around with some of the WAN settings tonight to turn off SIP ALG to see if this helps....
dctheobald
Jan 30, 2018Tutor
After turning off SIP ALB (under WAN settings) and Backhaul Daisy Chain Topology (under Advanced Setup>Wireless settings) it seems the satellite isn't dropping my wired in VOIP, but the voice quality is still pretty choppy. Was hoping there was a QoS control settings but nothing seems to work in the hidden /QOS_main.htm page....
