dctheobald
Jan 28, 2018Tutor
Orbi Satellite dropping connection to VOIP
I have the RBR50 router and 2 RBS50 satellites - each device is on a separate floor of my 3 story house. They are close enough in proximity with each other as they do not show issues in the Orbi con...
t_k
Feb 08, 2018Luminary
I know your issue is specific to VOIP, but I believe I know what you're running into. I believe it's likely that what you're seeing is the various WDS (backhaul) issues that show up with the Orbi's. Especially with devices that are "chatty".
If I'm right, and what would be hard to prove unless you can make your VOIP device use a different MAC, there is nothing you can do about it. Here's my related post. Hopefully it saves you some time.
dctheobald
Feb 08, 2018Tutor
Thanks for sharing, your summary is pretty helpful! I narrowed my issue down to the backhaul stability as well and found it wasn't just the VOIP but any high-bandwidth device like my Lifesize Video screen as well....i've decided to give the ethernet daisy chaining option a try but need to get an electrician out my office to install some cabling to try it due to the locations of my router and satellites. This is more work than i was hoping from this expensive system....
- t_kFeb 08, 2018Luminary
dctheobald - Since you mentioned wiring your office, I have more bad news! A few weeks ago I finally broke down and paid to have my home wired (which cost thousands of dollars). There are three people that work from my home frequently. After a year of being interrupted to look at the Orbi's multiple times almost every day, I finally caved and spent the money.
I know for certain that the ethernet backaul feature of the Orbi's, at least as of firmware version 2.1.2.18, is too unstable to use. There is no way to force the Orbi to use either the ethernet or wireless backhaul, and the system will not consistently stay on one or the other. The net effect is that you can end up with both the original stability issues (if an Orbi decides to use a wireless backhaul for whatever reason), or deal with a broadcast loop caused by a multi-path issue (both a wired and wireless path to a MAC address), or deal with random "cut outs" for all devices as the Orbi changes from using an ethernet vs wireless backhaul.
Also, even if the Orbi's stayed on the ethernet backhaul for the day, I still ended up having to restart one of them nearly every day.
Since I had paid to wire my home anyway, I spent $650 more and just bought a Unifi 5 pack. Litterally, 0 issues since then and it's been several weeks. No drops, no pauses, no complaints, it just works. I'm even able to do proper channel organization, though that's just a bonus. Interference was never the problems with the Orbi's. For reference, I have between 6-10 devices using traffic all day, and 20-30 devices using traffic intermittiedly.
If you're paying to wire the place, just get a more professional product (like Unifi's or, really, anything else).
- dctheobaldFeb 08, 2018Tutor
Good to know - thanks! I figured wiring my home office had two main options:
1) hard wire the daisy change between the Orbi router and the satellite in my office
or
2) hard wire my VOIP and video screen directly throught the wall to the router and let the satellite operate on wifi on it's own - essentially move the chatty devices directly into the router.
I had no issues with setup #2 previously when the router was physically in my office so i suspect this is the way to go.
Kind of a bummer to have to buy $500 system just to dump it due to instability.... grrr.
