bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
DarrenM
Aug 03, 2017Sr. NETGEAR Moderator
If you could send me a private message with your name,email and phone number our support team can work with you on the drop connections you are having with the latest firmware.
DarrenM
JRTTulsa
Aug 25, 2017Initiate
I am having the same connection dropping problem despite running the latest fw.
- JRTTulsaAug 25, 2017Initiate
Removed your Info but I have it - DarrenM
- DerekBerubeAug 25, 2017Tutor
Support provided instructed me to go to the Admin Page -> Advanced -> Advanced Setup -> Wireless Settings page and remove the check mark from the "Enable 20/40 MHz Coexistence" option.
They also wanted me to uncheck the following options, but they had already been unchecked.
- Enable Implicit BEAMFORMING
- Enable MU-MIMO
Attached is a before/after screen shot of that particular setting.
I'm testing that configuration now.
- seamarkAug 29, 2017Initiate
Darren,
I sent the requested contact information to you on Friday via private message. Did you receive it?
Thanks.
Mark
