bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
JRTTulsa
Aug 25, 2017Initiate
I am having the same connection dropping problem despite running the latest fw.
JRTTulsa
Removed your Info but I have it - DarrenM
- DerekBerubeAug 25, 2017Tutor
Support provided instructed me to go to the Admin Page -> Advanced -> Advanced Setup -> Wireless Settings page and remove the check mark from the "Enable 20/40 MHz Coexistence" option.
They also wanted me to uncheck the following options, but they had already been unchecked.
- Enable Implicit BEAMFORMING
- Enable MU-MIMO
Attached is a before/after screen shot of that particular setting.
I'm testing that configuration now.
- seamarkAug 29, 2017Initiate
Darren,
I sent the requested contact information to you on Friday via private message. Did you receive it?
Thanks.
Mark- DarrenMAug 29, 2017Sr. NETGEAR Moderator
Hello Seamark
Yes I did If you sent it late on friday then I sent it to support yesterday they should be contacting you soon.
DarrenM
- BarryTregNov 16, 2017Apprentice
Several of my wireless clients were annoyingly dropping connections (Lenovo Android Yoga Book, Galaxy s7, Dell laptop E6230) and unticking the 20/40Mhz coexistence box appears to have sorted it out - 12 hours and no disconnects so far. Took a while to work through the many suggestions on the forums.... that was a bit of a journey!
- mrtelarcNov 17, 2017Tutor
Thanks for the info which I would like to try. Can you help wirth how to reach where said box is to untik is located?
