bluefish10
Aug 02, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
JRTTulsa
Aug 25, 2017Initiate
Removed your Info but I have it - DarrenM
DerekBerube
Aug 25, 2017Tutor
Support provided instructed me to go to the Admin Page -> Advanced -> Advanced Setup -> Wireless Settings page and remove the check mark from the "Enable 20/40 MHz Coexistence" option.
They also wanted me to uncheck the following options, but they had already been unchecked.
- Enable Implicit BEAMFORMING
- Enable MU-MIMO
Attached is a before/after screen shot of that particular setting.
I'm testing that configuration now.
- seamarkAug 29, 2017Initiate
Darren,
I sent the requested contact information to you on Friday via private message. Did you receive it?
Thanks.
Mark- DarrenMAug 29, 2017Sr. NETGEAR Moderator
Hello Seamark
Yes I did If you sent it late on friday then I sent it to support yesterday they should be contacting you soon.
DarrenM
- schnobertsAug 30, 2017TutorHi,
I have the exact same issue. Bought the Orbi last week. It was running 3 days before the satellite and hub stopped talking. Now they won't resync.
I'm just going to bundle this stuff back into its box and return it. Life is too short when there's other products out there.
- BarryTregNov 17, 2017Apprentice
Several of my wireless clients were annoyingly dropping connections (Lenovo Android Yoga Book, Galaxy s7, Dell laptop E6230) and unticking the 20/40Mhz coexistence box appears to have sorted it out - 12 hours and no disconnects so far. Took a while to work through the many suggestions on the forums.... that was a bit of a journey!
