bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
NoWiFi4U
Sep 28, 2017Star
I too am having issues with my orbi wifi system. the information below.
-Bought the 3 Orbi system (RBR40, 2x RBS40) from Best Buy about 9 months ago. It was working great for the first 6 months or so. I then had issues with one of my satellites dropping off daily. I would have to reset the orbi satellite and it would reconnect.
- the main Orbi is in the center of the house. 1 is on one side (kids rooms) and the other is on the other side of the house (master bed). The master bed Orbi is the only one I constantly have issues with.
- I have also tried doing a factory reset on the main router with no luck.
- Current firmware is V2.0.0.56. I have tried clicking the check for updates, but there are no updates.
- The orbi with the issue (master bed) is approx 26 ft from the main Orbi router. 1 wall separates the two. I have tried moving the orbi satellite with no improvement.
- I am not sure what other info you need but will provide additional info if requested.
I also sent DarrenM a PM. :)
HockeyStick
Oct 03, 2017Star
I'm running firmware version 2.0.0.74 and twice today I experienced no internet connection when one my satellites was powered on and supposedly functioning normally. I have to unplug the satellite, and then boom, my connection returns because my devices switch to a connection to the base.
What a piece of junk.
- bowmahOct 03, 2017Guide
My Satellite has hardly dropped to the point where the blue light comes on. It has been blue for almost 20 hours now. Unplugged it and it came back to life. This is on: V2.0.0.72
Noticed .74 is ready for update, will try that. How can this happen with so many months of happy connecting? :(
- OrbiWanOct 04, 2017GuideI have wireless clients right next to my 2 satellites but they still connect to the router 50 feet away and get bad throughput.
- st_shawOct 04, 2017Master
OrbiWan wrote:
I have wireless clients right next to my 2 satellites but they still connect to the router 50 feet away and get bad throughput.If you want help with a specific issue, you should start a new thread and describe in detail what's happening in your specific case. Meanwhile.... Note that WiFi clients ultimately decide what AP to connect to and whether to switch. Some clients never switch once they latch onto an AP, as long as they can still see that AP. You might have to reboot some clients (or power-cycle a client's WiFi) to get them to connect to the strongest AP. MacOS devices are in this category, as are many IP cameras. Also, understand that you may need to do this any time your Orbi reboots. This is becaue the router will come up first, before the satellites, and some clients will connect to the router, then never switch to the satellite, regardless of signal strength.
