bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
bowmah
Oct 03, 2017Guide
My Satellite has hardly dropped to the point where the blue light comes on. It has been blue for almost 20 hours now. Unplugged it and it came back to life. This is on: V2.0.0.72
Noticed .74 is ready for update, will try that. How can this happen with so many months of happy connecting? :(
OrbiWan
Oct 04, 2017Guide
I have wireless clients right next to my 2 satellites but they still connect to the router 50 feet away and get bad throughput.
- st_shawOct 04, 2017Master
OrbiWan wrote:
I have wireless clients right next to my 2 satellites but they still connect to the router 50 feet away and get bad throughput.If you want help with a specific issue, you should start a new thread and describe in detail what's happening in your specific case. Meanwhile.... Note that WiFi clients ultimately decide what AP to connect to and whether to switch. Some clients never switch once they latch onto an AP, as long as they can still see that AP. You might have to reboot some clients (or power-cycle a client's WiFi) to get them to connect to the strongest AP. MacOS devices are in this category, as are many IP cameras. Also, understand that you may need to do this any time your Orbi reboots. This is becaue the router will come up first, before the satellites, and some clients will connect to the router, then never switch to the satellite, regardless of signal strength.
- ispOct 07, 2017Tutor
I had similar problems: satellite losing connection intermittently but frequently, immediately after an automatic upgrade to the v2.0.0.74 firmware.
In my case, disabling the new Daisy-Chain topology option resolved the problem.
In the admin settings: Advanced -> Wireless Settings -> Backhaul Topology. Disable "Enable Daisy-Chain Topology".
(More info about my setup: RBK50, with 3x RBS50, operating in Router mode. After the firmware auto-upgrade, one of the RBS50 satellites lost connectivity for ~10 minutes at a time, about 1-2 times per hour. Restarting the router & satellites moved the dropping connection problem to a different satellite instead, i.e., at any time router & 2 satellites were OK, but a different 1 satellite kept dropping connection. The 2 satellites that each showed the problem are within range of each other, as well as within range of the router. No visible indication of the connection being dropped in the ring LED. Ping to the router showed no problems - it worked with 100% success and normal low ping times, then dropped to 0% success, then back to 100% success, etc. Disabling Daisy-Chain Topology, which does an automatic restart, and no further problems since.)
- OrbiWanOct 07, 2017Guide
I have everything disabled, included uPnP.
Can you tell me if your clients in the same room of the satellites are connecting to it or is it connected to the router?
