bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
isp
Oct 07, 2017Tutor
I had similar problems: satellite losing connection intermittently but frequently, immediately after an automatic upgrade to the v2.0.0.74 firmware.
In my case, disabling the new Daisy-Chain topology option resolved the problem.
In the admin settings: Advanced -> Wireless Settings -> Backhaul Topology. Disable "Enable Daisy-Chain Topology".
(More info about my setup: RBK50, with 3x RBS50, operating in Router mode. After the firmware auto-upgrade, one of the RBS50 satellites lost connectivity for ~10 minutes at a time, about 1-2 times per hour. Restarting the router & satellites moved the dropping connection problem to a different satellite instead, i.e., at any time router & 2 satellites were OK, but a different 1 satellite kept dropping connection. The 2 satellites that each showed the problem are within range of each other, as well as within range of the router. No visible indication of the connection being dropped in the ring LED. Ping to the router showed no problems - it worked with 100% success and normal low ping times, then dropped to 0% success, then back to 100% success, etc. Disabling Daisy-Chain Topology, which does an automatic restart, and no further problems since.)
OrbiWan
Oct 07, 2017Guide
I have everything disabled, included uPnP.
Can you tell me if your clients in the same room of the satellites are connecting to it or is it connected to the router?
- ispOct 07, 2017Tutor
OrbiWan wrote:Can you tell me if your clients in the same room of the satellites are connecting to it or is it connected to the router?
Yes, my clients tend to connect to the closest satellite. (Verified using Android app "WiFi Analyzer".)
I also have computers connected to each satellite by Ethernet cable. This made the intermittent connection drop I described above very easy to detect.
- OrbiWanOct 07, 2017Guide
Try looking in the orbi set up page under "attached devices".
So you don't have a lemon then. Well I'm pretty techy when it comes to setting this stuff up and I've tried everything to factory resets to turning on each satellite sequentially. I get blue strong signal and satellites in line of sight with less than 50 feet from each other. I'm going to hang on for 1 more week and if no firmware updates fix this simple problem, it's going back to the shop. Thanks for the input everyone.
