bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
isp
Oct 07, 2017Tutor
OrbiWan wrote:Can you tell me if your clients in the same room of the satellites are connecting to it or is it connected to the router?
Yes, my clients tend to connect to the closest satellite. (Verified using Android app "WiFi Analyzer".)
I also have computers connected to each satellite by Ethernet cable. This made the intermittent connection drop I described above very easy to detect.
OrbiWan
Oct 07, 2017Guide
Try looking in the orbi set up page under "attached devices".
- OrbiWanOct 07, 2017Guide
So you don't have a lemon then. Well I'm pretty techy when it comes to setting this stuff up and I've tried everything to factory resets to turning on each satellite sequentially. I get blue strong signal and satellites in line of sight with less than 50 feet from each other. I'm going to hang on for 1 more week and if no firmware updates fix this simple problem, it's going back to the shop. Thanks for the input everyone.
