bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
bluefish10
Oct 12, 2017Guide
Ok, this is getting ridiculous. We held off of installing the beta in the hopes that the next official update would fix things. But no, it's still going on. Absolutely ridiculous. For anyone looking for a fix right now, the one thing that actually works is unplugging the satellite in question. This means if your device gets disconnected, unplug the satellite closest to that device. Sad that netgear can't figure this out, I'm sure this issue is quite widespread.
- HockeyStickOct 13, 2017Star
For anyone with the problem, ^ this is the ONLY solution. Netgear hasn't done squat to fix this, and its been eons. This, and never buy another Netgear product again. If you are even considering the Orbi, DON'T BUY IT!
- GubbenPatrikOct 13, 2017AspirantStill, there is the option go install firmware 1.11.0.20 (or earlier), and the system will work as expected. I'm now happy with my Orbi.
- ztevieOct 14, 2017GuideIt's not an acceptable solution to be forced to use old firmware without all announced functionality, just to have a functional device.
If you buy something else, let's say a TV, would you be happy if it turns off now and then, and the solution is to only watch certain channels? It works so it's ok...
