bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
bluefish10
Oct 12, 2017Guide
Ok, this is getting ridiculous. We held off of installing the beta in the hopes that the next official update would fix things. But no, it's still going on. Absolutely ridiculous. For anyone looking for a fix right now, the one thing that actually works is unplugging the satellite in question. This means if your device gets disconnected, unplug the satellite closest to that device. Sad that netgear can't figure this out, I'm sure this issue is quite widespread.
HockeyStick
Oct 13, 2017Star
For anyone with the problem, ^ this is the ONLY solution. Netgear hasn't done squat to fix this, and its been eons. This, and never buy another Netgear product again. If you are even considering the Orbi, DON'T BUY IT!
- GubbenPatrikOct 13, 2017AspirantStill, there is the option go install firmware 1.11.0.20 (or earlier), and the system will work as expected. I'm now happy with my Orbi.
- ztevieOct 14, 2017GuideIt's not an acceptable solution to be forced to use old firmware without all announced functionality, just to have a functional device.
If you buy something else, let's say a TV, would you be happy if it turns off now and then, and the solution is to only watch certain channels? It works so it's ok...- GubbenPatrikOct 14, 2017AspirantOf course, if there is funtionality you really need in newer version, that is a problem. But if you simply are after a stable wifi coverage in all of your house, like me, downgrading to older workable firmware is a perfect solution. There is no funtionality I ask for in the newer versions of the firmware and I will rather wait for a stable version before upgrading again.
- OliverpoolOct 31, 2017Guide
But it keeps auto updating to the newest version automatically after a while! I have never had any item that upgrades their firmware automatically! Crazy and silly. Netgear please get your act together!
- GubbenPatrikNov 01, 2017AspirantLiverpool, see post 73 which contains links to how to stop autoupdate.
