bluefish10
Aug 02, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
GubbenPatrik
Oct 14, 2017Aspirant
Still, there is the option go install firmware 1.11.0.20 (or earlier), and the system will work as expected. I'm now happy with my Orbi.
ztevie
Oct 14, 2017Guide
It's not an acceptable solution to be forced to use old firmware without all announced functionality, just to have a functional device.
If you buy something else, let's say a TV, would you be happy if it turns off now and then, and the solution is to only watch certain channels? It works so it's ok...
- GubbenPatrikOct 14, 2017AspirantOf course, if there is funtionality you really need in newer version, that is a problem. But if you simply are after a stable wifi coverage in all of your house, like me, downgrading to older workable firmware is a perfect solution. There is no funtionality I ask for in the newer versions of the firmware and I will rather wait for a stable version before upgrading again.
- ztevieOct 14, 2017GuideI know, I'm just frustrated with companies using resources to develop new functionality before the basic functions are stable.
Netgear's not alone, I've seen this with other brands aswell. They develop all these bells and whistles functionality and use it in ads to sell. Then when everything go south the solution is often to not use those new functions....- TritianOct 14, 2017Tutor
I RMA'd my router. GOt everything setup on 2.0.0.74. I have been up and solid connections for 15 days. Not one single drop.
