bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
Tritian
Oct 14, 2017Tutor
I RMA'd my router. GOt everything setup on 2.0.0.74. I have been up and solid connections for 15 days. Not one single drop.
BrianBB
Oct 23, 2017Aspirant
I am on Router Firmware Version V2.0.0.74 and have the satellites dropping conections constantly. The problem became worse once moving to 2.0.0.74 from 2.0.0.72. So the problem is far from fixed
- st_shawOct 23, 2017Master
If you had these issues and they got worse with .74, you should try moving your router and/or satellites so they are closer and/or have fewer walls and building materials in between them. The satellites will drop if they do not have a good and stable signal over time. The latest firmware seemed to reduce the satellite to router range for some folks and moving things solved thier issues.
- OrbiWanOct 23, 2017GuideRun Forrest, run! From a post before, you shouldn't have to do so much work upgrading firmware, trying to play with setting, moving them to the correct sun angle, cutting against the grain. I've done all I can and I'm so happy with my old router. Return it before your window is closed.
