bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
DezM
Nov 15, 2017Star
Everyone. Just be sure to update the satellite FIRST and than update the router when applying firmware updates. Early on, I updated the router first and I assumed both the router and satellite were updated. I was wrong. I found out the hard way when I was getting constant disconnections and internet disruptions.
I figured out that my satellite had OLD firmware as opposed to newer firmware in the router. I found out by shutting off my router, connecting my laptop to the satellite's Ethernet port and logging in to the satellite. Enter login and password which warned me that i was not connected to my router. I hit OK and noticed that my satellite was running v1.11xx firmware. Earlier, I had downloaded the newest firmware for the satellite and applied it via the Firmware update page inside the satellite. I did a manual install.
After successfully updating the satellite and disconnecting my Ethernet cable to the laptop, I turned on my router and both synced. Now I see the satellite as an Attached Device in my router. Hopefully, now I'll see consistent connections and fast internet speeds i was accustomed to with the Orbi.
