bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
mich1973
Feb 17, 2018Tutor
As an update, it's interesting to see that Netgear now shows firmware V2.0.1.4 as the current firmware and all of V2.1.* is flagged as previous. So, I just downgraded for my RBR50 and RBS50 and it did solve the problem of the disconnecting satellite for me.
Have a look .. You don't need to throw your Orbi away ..
Michael
Jvreeman
Feb 17, 2018Star
Thank you for responding to the thread with this! I just downgraded the firmware to the new old V2.0.0.53 firmware for the RBR40 and RBS40 units.
Have Wifi Explorer running and will be monitoring the connections. Fingers crossed this resolves the issue.
Thank you, again!
- QuickscanFeb 17, 2018GuideHi, how are you ‘downgrading’ the firmware. I can’t see an option to do this.
Thanks
Dan- st_shawFeb 17, 2018Master
Thanks
DanDownload the firmware to a PC from the NETGEAR website then manually upload it to the Orbi.
Thanks alot. Done it. Fingers crossed. I am pretty close to getting rid of them.
- Jclapper1814Feb 17, 2018StarDan - Download the version you want from Netgear’s website; log into the firmware on the router, go to advanced settings and then manually update. Start with satellites and then do the router. Hope this solves it for you.
