bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
Apr 03, 2018Guru - Experienced User
Well mines been online for 3 days + with out any reboots since last update and re-config. May also depend on ISP modem and services as well and other environmental conditions could impact as well. Just saying.
Hope the new FW will exhibit something different.
- myriad_rockerApr 04, 2018Apprentice
I'm glad that it's working well for you. The jury is still out for me until I have the time in my hectic schedule to do the reconfig. I own my modem and it's a DOCSIS 3. My previous 2 routers have been just fine and I never had to worry about drops or slow speeds. There's many documented cases of other users swapping out the Orbi for something else and all was well.
We'll see what this new FW brings, but for now, it's beta. So I still say it's garbage until they are creating features and not just scrambling to fix memory leaks and the like.
- FURRYe38Apr 04, 2018Guru - Experienced User
Let us know how it goes.
Good Luck.
myriad_rockerwrote:I'm glad that it's working well for you. The jury is still out for me until I have the time in my hectic schedule to do the reconfig. I own my modem and it's a DOCSIS 3. My previous 2 routers have been just fine and I never had to worry about drops or slow speeds. There's many documented cases of other users swapping out the Orbi for something else and all was well.
- WillBillApr 04, 2018TutorUpgraded to FW 2.1.3.4 on the RBR50 and RBS50; downgraded the RBW30 to FW 2.0.1.2 per Netgear’s website. Disconnects are more frequent with the Harmony Hub and today it disconnected when My HP printer WiFi printed. Can’t take it much longer with disconnects multiple times per day. Talked with Crutchfield (in US) and they do not recommend the Netgear Orbi. It’s sad because when it’s operating the speeds are good everywhere on my property. I understand why the Harmony Hub will have trouble with mesh WiFi, but don’t understand the disconnect of the RBR50, then about 20 other devices take about 10 minutes to recovery after we discover the disconnect.
- myriad_rockerApr 07, 2018Apprentice
Alright, so...here's my update. As you may or may not know, I'm on the beta 2.1.3.4 firmware. I updated the Orbi without doing a reset on anything for a few days. I still had everything on timers to force power cycles on the previous firmware (because that's all that kept the drops and slow speeds at bay). I left them on those timers for about 2 days or so and then had the chance to reset the RBS50.
In the scenario above, everything was just ok. I still got some split second drops on my Samsung phone and speeds were just "acceptable". I went for about 3 days in this config because I didn't have time to reset the RBR50 and doing the reconfig.
Fast forward to a few days ago and before I went to bed one night, I did the RBR50 reconfig and took everything OFF of the timers. Just to get a good idea of how things were going to go, I enabled most things I had previously disabled before. Guest network, Beam Forming, MU-MIMO, and Fast Roaming. So far things have been going alright. Around the same time Netgear issued a fallback on the RBW30 firmware. I haven't messed with that one at all. But I only connect to it when I'm out in the shop and I haven't been out there in a month.
Now to the actual performance. So far, everything is ok. I have not witnessed any disconnects. I've been periodically doing speed tests and it's hit or miss, but just ok. My phone (Samsung Galaxy S7) has been speedtesting respectable. Between 50mbps and 75mbps. Today it's doing over 100mbps, which is nice to see. I pay for 100mbps service, BTW. For my laptop, it's not near as good. It routinely gets between 15mbps and 45mbps. It does what I need it to do, but it's still annoying to see that.
So I started poking around in the settings and doing some research. Granted, this is an older laptop. Back when Windows 8 was new is when I bought it. I thought I had recently updated the driver on it, but turns out I hadn't. It was a driver from 2015. I updated that and it loaded a driver from January of this year. I did a restart and then checked cmd to see how it was connected. I also read something about disabling IPv6 on this specific Intel NIC. So I did that. While I was at it, I set the a/b/g wireless mode to 5Ghz only. After this, the laptop is getting about 75mbps.
I'm going to leave things alone for a few days and continue testing. Eventually I'll get around to updating the RBW30, but I'm wondering if they've released an updated beta for that as well.
- FURRYe38Apr 07, 2018Guru - Experienced User
Glad its working much better.
No router needs timers if there set up well and the environment is good. I've never had to use any timers. I do keep a laptop cooler under my router to additional cooling is all.
Let it run and keep us posted. Enjoy.
myriad_rocker wrote:Alright, so...here's my update. As you may or may not know, I'm on the beta 2.1.3.4 firmware. I updated the Orbi without doing a reset on anything for a few days. I still had everything on timers to force power cycles on the previous firmware (because that's all that kept the drops and slow speeds at bay). I left them on those timers for about 2 days or so and then had the chance to reset the RBS50.
