bluefish10
Aug 02, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
RogerSC
May 15, 2018Virtuoso
DESIi1 wrote:
After much testing and swapping equipment, it was proven that Comcast's Arris modem is not compatible with Orbi on AP mode. Testing in pass-through was not done. Switching to a Netgear owner supplied cable/phone modem resolved the issue. You likely will need a capable Comcast tech to help make the switch.
Glad that you found your problem, the Orbi is great when it works as it should *smile*. Wondering which specific model Arris modem it was? I used the Arris TM822g modem with the Orbi for quite a while, in both router or AP mode and no problems. Maybe it was that specific modem, that it wasn't working right? Don't know if you tried multiple units of that cable modem? Anyways, glad to hear your problems are fixed!
Also, Comcast now has a process called auto-activation where you disconnect the old modem and connect the new one. Then attach a computer to it, and bring up a browser, and if it's a supported modem it should start to auto-activate. The first part of the process is identifying yourself/account, and there are several ways to do that. That worked for me recently with both the Netgear CM500V and the Netgear C7100V (that I beta tested). The cable modem auto-activation process is described on the Comcast site, where it talks about your devices, and how to replace your modem. Very simple and quick these days.
May 15, 2018Guru - Experienced User
I put a 40 series on a TM722G the other day. Had a hard time getting good connections and wireless was goofy. After bridging the Arris modem and doing a full factory reset on Orbi system and setting up from scratch. Been great.
Not a fan of Arris modems though. :smileytongue:
- RogerSCMay 15, 2018Virtuoso
I had an Arris TM722g for several years, very solid. You don't bridge a cable modem, it doesn't have a router section, so you don't even get the choice of bridge mode (of course). Anyways, the TM722g served me well until my download speed was raised to a higher speed than it would support. Upgraded to an Arris TM822g, and it also was solid and served me well. Again, my download speed was raised to more than the TM822g modem would support. I'm now using a Netgear CM500V to support 300Mbps. Which I don't see at prime time in the evening, down around 80-150Mbps usually then. I just love Comcast and their monopoly (here).
Anyways, never had a problem with Arris cable modems, they've just worked for me. The Netgear one that I have now is doing the same *smile*.
- FURRYe38May 16, 2018Guru - Experienced User
Interesting, this modem has one. Also has a bridge UI feature. I tried it and it works. Buddy is happy with it. I'm thinking he might get one instead of a R7800 and extender set up. His home this THICK so I noticed that where I placed the router and satellite, signal was POOR. So after conencteing wired back haul, he's happy. Placement isn't the best however seems to work for now. May do some more placement review to get better results.
