bluefish10
Aug 02, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
Hsc1102
Aug 30, 2018Apprentice
Perpetual purple... wtf
Hsc1102
So tired of this
- zekaonarAug 30, 2018Guide
I have to say Netgear permanently lost my business with this product and their tech support of it. I feel scammed and when I see that Amazon still has this product at close to 5 stars you know they are gaming the reviews. At least the critical reviews are getting marked helpful and hopefully some people pause an research a bit more before clicking buy. Netgear deserves to loose business over this POS. If the product didn't suck we wouldn't notice their support is so bad.
- FURRYe38Aug 31, 2018Guru - Experienced User
If you give us some details of whats going on, maybe we can help you out here in the forum.
- Retired_MemberAug 31, 2018
Furry, and the other forum helpers. I think it's quite obvious the firmware has SIGNIFICANT issues, and rather than asking everyone the same questions, and providing the same answers. is it possible to get Netgear's engineering team to give us an ETA on a fix for this "Drop out" situation?
Have you asked for the new beta thats available?
Router mfrs don't give information on when FW will be released.
One user mentioned going back to v.10 FW helped them...
- jblack68Sep 01, 2018ApprenticeI had problems trying to re connect the Satellite - would show as attached devices on the router page and the speeds would be limited to 11mbps. I managed to get it reconnected by disconnecting the Ethernet devices on the satellite and turning the power switch on it off and on and seemed to work.
- prasen82Sep 01, 2018Aspirant
I purchased it this may. it was working finr. since last 10 days it has been dropping connections left right and center only to work upon powering off and poweing on. its connected to spectrum through motorola docis modem sb6121.
had an asus tmobile cellspot router earlier. no problem. Now this is like super junk.
i believe this has warranty still but what to do if the system does not work. phone and chat support not available.
i also upgraded to latest firmware V2.1.4.16
- FURRYe38Sep 02, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a reset been performed after the FW as updated and set up from scratch?
- prasen82Sep 04, 2018AspirantHi,
The modem is Motorola docsis sb6141.home is 3500 and satellite is in second floor while router is in first floor.
I will try the rest and let you know what I observe. This started happening over the last 1 month.
