bluefish10
Aug 02, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
Aug 31, 2018Guru - Experienced User
Have you asked for the new beta thats available?
Router mfrs don't give information on when FW will be released.
One user mentioned going back to v.10 FW helped them...
Retired_Member wrote:
Furry, and the other forum helpers. I think it's quite obvious the firmware has SIGNIFICANT issues, and rather than asking everyone the same questions, and providing the same answers. is it possible to get Netgear's engineering team to give us an ETA on a fix for this "Drop out" situation?
jblack68
Sep 01, 2018Apprentice
I had problems trying to re connect the Satellite - would show as attached devices on the router page and the speeds would be limited to 11mbps. I managed to get it reconnected by disconnecting the Ethernet devices on the satellite and turning the power switch on it off and on and seemed to work.
- prasen82Sep 01, 2018Aspirant
I purchased it this may. it was working finr. since last 10 days it has been dropping connections left right and center only to work upon powering off and poweing on. its connected to spectrum through motorola docis modem sb6121.
had an asus tmobile cellspot router earlier. no problem. Now this is like super junk.
i believe this has warranty still but what to do if the system does not work. phone and chat support not available.
i also upgraded to latest firmware V2.1.4.16
- FURRYe38Sep 02, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a reset been performed after the FW as updated and set up from scratch?
- prasen82Sep 04, 2018AspirantHi,
The modem is Motorola docsis sb6141.home is 3500 and satellite is in second floor while router is in first floor.
I will try the rest and let you know what I observe. This started happening over the last 1 month.
