bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
RAJAC
Jan 07, 2019Aspirant
My orbi satellites are loosing connection all the time they work next to each other but not solving the problem they were bought for
Please help me
Please help me
ekhalil
Jan 07, 2019Master
Please help me
RAJAC, I think it's better if you create a new discussion for your issue and provide enoigh information about your setup so you can get the needed attention.
Thank you,
- j1nJan 15, 2019ApprenticeI’ve noticed FURRYe38 has mentioned many times on this forum that “If you updated to recent FW v.210, try enabling Daisy Chain. SOME have mentioned that this SEEMS to be working in reverse order, enabling means disabled actually.”
Can anyone actually verify if enabling Daisy Chain actually turns this setting off within the current Firmware (v2.2.1.210)?- ekhalilJan 15, 2019Master
Can anyone actually verify if enabling Daisy Chain actually turns this setting off within the current Firmware (v2.2.1.210)?Daisy Chain is enabled when it's ticked in the settings and disabled when unticked in the settings.
You can see this by making a wifi scan after you enable Daisy Chain (ticked in the settings) where you will see that each satellite will start broadcasting an own hidden 5 GHz network to allow other satellites to connect to.
When Daisy Chain is disabled (unticked in the settings) only the router will broadcast this hidden wireless 5 ghz network so the satellites will be only able to connect to the router (start setup) and not to another satellite (Daisy Chain).
