bluefish10
Aug 02, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
j1n
Jan 15, 2019Apprentice
I’ve noticed FURRYe38 has mentioned many times on this forum that “If you updated to recent FW v.210, try enabling Daisy Chain. SOME have mentioned that this SEEMS to be working in reverse order, enabling means disabled actually.”
Can anyone actually verify if enabling Daisy Chain actually turns this setting off within the current Firmware (v2.2.1.210)?
ekhalil
Jan 15, 2019Master
Daisy Chain is enabled when it's ticked in the settings and disabled when unticked in the settings.
You can see this by making a wifi scan after you enable Daisy Chain (ticked in the settings) where you will see that each satellite will start broadcasting an own hidden 5 GHz network to allow other satellites to connect to.
When Daisy Chain is disabled (unticked in the settings) only the router will broadcast this hidden wireless 5 ghz network so the satellites will be only able to connect to the router (start setup) and not to another satellite (Daisy Chain).
