Landy25
Apr 25, 2022Guide
ORBI Satellite drops Connection as soon as I connect it to a switch
I have a few ORBI AC3000 satellites. I always had one satellite providing network to an 8 port Netgear switch and have never had an issue. For a few days now as soon as I connect the switch to the s...
- Apr 25, 2022
there is a newer version you can try. Make sure to update the satellites first, then the router.
Apr 25, 2022Guru - Experienced User
Try connecting only the switch with nothing connected to the switch.
What switch are you using?
- Landy25Apr 25, 2022Guide
I have a simple Netgear unmanaged switch and I also tried a Zylxel switch. I did try without anything else connected to the switch and it still happened. It literally happens as soon as I connect the switch.
