vinesh
Dec 31, 2017Guide
Orbi Satellite Ethernet Backhaul and other ethernet devices issue
When connecting the Orbi Satellite via ethernet backhaul as soon I plug another device into any of the LAN ports and reboot the satellite it won't connect back to the router and I need to reset the d...
- Jan 04, 2018
Is your Orbi Router in router mode or access point mode? If in access point mode, you need to connect your Orbi router to your regular router via one of the Orbi LAN ports (not WAN port) to fix this. Then the Orbi satellite can communicate with the Orbi router via ethernet. I posted a more detailed explanation previously but it was moderated/deleted.
