vinesh
Dec 31, 2017Guide
Orbi Satellite Ethernet Backhaul and other ethernet devices issue
When connecting the Orbi Satellite via ethernet backhaul as soon I plug another device into any of the LAN ports and reboot the satellite it won't connect back to the router and I need to reset the d...
- Jan 04, 2018
Is your Orbi Router in router mode or access point mode? If in access point mode, you need to connect your Orbi router to your regular router via one of the Orbi LAN ports (not WAN port) to fix this. Then the Orbi satellite can communicate with the Orbi router via ethernet. I posted a more detailed explanation previously but it was moderated/deleted.
vinesh
Jan 04, 2018Guide
Thank you! That solved the issue, yes I'm using Orbi in AP mode
MikeMcr
Jan 04, 2018Guide
Great. There is a reddit posting called "Ethernet Backhaul How-To" that describes more detail in the comments but linking to it probably got my original post deleted. Thanks go to the people over there for how to fix this issue. If you discover the Orbi router LED now goes magenta meaning no internet access (even though you do), you just have to connect any always on device to the WAN port and that turns off the LED.
- vineshJan 04, 2018Guide
Thanks :) yes that solid magenta light was the next annoyance.
