kwtb2488
May 19, 2020Aspirant
Orbi Satellite Failing to Sync
Hi ive had the Orbi wireless system in my two story condo for a few years. The upstairs internet sometimes is spotty (i have the Orbi downstairs) so i got another satellitte to help improve it. Howev...
CrimpOn
May 19, 2020Guru - Experienced User
My practiced has been to sync the satellite in the same room as the Orbi so that I can watch both of them as it happens. After the satellite syncs and the Orbi web interface reports "good", then I relocate the satellite to the remote location.
Immediately above (or below) the Orbi router is probably not as desirable as being "offset". WiFi access points typically have omnidirectional antennas which radiate mostly in the horizontal plane. After it syncs correctly next to the router, you can try moving it around to see which location gets a "good" connection.
