Davidporges
Mar 06, 2017Follower
Orbi Satellite fails to sync to router
Despite my best efforts my Satellite refuses to connect to my Orbi Router. I've tried syncing it both thorugh the website and manually via the sync button and both won't work. the satellite pulses wh...
Hydro130
Mar 06, 2017Luminary
In just a small apartment, Orbi is probably not a good system for you...
If the router and satelite are too close together (as they likely would be in a small apartment), then the overlapping wireless coverage from each unit will likely cause ongoing connection problems for your devices (since they'll have two strong newtwork "sources" to constantly be choosing between).
A traditional single-unit router would be a better choice for use in a small apartment.
