MiTn
Jan 03, 2017Tutor
Orbi Satellite Firmware update
My ORBI RBR50 router is current with latest Firmware, but it appears my SatelliteRBS50 is not. How do I update it?
- U need to update manually. I bought mine yesterday. I used this method for the firmware http://kb.netgear.com/31485/How-do-I-manually-upgrade-firmware-to-my-Orbi-Router?cid=wmt_netgear_organic
- MarkC1024Luminary
There is a tab on the Admin page to do it manually. First download the correct version for the satellites, RBS50*, then follow the instructions on that tab.
- Ares24Tutor
I'm having the opposite issue. I just bought my Orbi system a few hours ago. My satalite updated but my router will not. I have even tried to download the .img file manually and browse to that file but it has the same effect. It just stits there with a spinning circle that says "please wait a moment". Been doing that for about 30 min now.
- RustproofcornLuminaryU need to update manually. I bought mine yesterday. I used this method for the firmware http://kb.netgear.com/31485/How-do-I-manually-upgrade-firmware-to-my-Orbi-Router?cid=wmt_netgear_organic
- MiTnTutor
Thanks was able to get mine to update!
- RustproofcornLuminaryNo problem!!
