JimiPhx
Nov 11, 2020Aspirant
Orbi Satellite Interferes with BlueTooth Headphones
Every time I walk by my Satellite, while wearing my earphones connected to the phone in my pocket, the BT disconnects. There is a closed topic on this, with no solution. I haven't tried anything ...
Nov 11, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz.
For the most part, there probably isn't any thing that can be done, BT runs on or near same frequency and most 2.4ghz wifi routers. So distance in between will be best option.
JimiPhx
Thanks for the response. I’ll give it a try!
I may end up moving the satellite too, except it’s in a location where all cables are hidden right now and moving it will look bad. So I’ll have to get creative.
Thanks,
Jimi
Thanks,
Jimi
