coffee_boy
Apr 11, 2020Aspirant
Orbi satellite is not accepting wifi connections
Not sure what's going on but for the last 2-3 days I've been having issues connecitng to the wifi, more often than not it is the Satellite device. Set-up RBR50 is connected to a Virgin Media hub...
coffee_boy
Cheers for the reply Jim.
The things is that whilst I'd agree with that sort of thing as I don't usually change firmware unless I have to, I had the problem before the upgrade. The upgrade was done to see if that cured the issue...
Retired_Member
Apr 11, 2020
coffee_boy wrote:Cheers for the reply Jim.
ok...lesson learned.
I still would roll back
systems don't break on their own
