noinse12
Aug 17, 2019Follower
Orbi satellite keeps switching to wired backhaul!!!
My satellite keeps switching to wired back haul, however there is no wired connection, so this ends up partitioning my network into two halves. I'm hoping someone might have a clue why. Both are in ...
Aug 17, 2019Guru - Experienced User
See if you can disable ALL IGMP Protocols on the switch after checking operation of Orbi with out the switch being online.
noinse12 wrote:My satellite keeps switching to wired back haul, however there is no wired connection, so this ends up partitioning my network into two halves. I'm hoping someone might have a clue why.
Both are in AP mode, DHCP is controlled by a server on my network, the router is a Netgear lb1120 (lte modem). I also have a Netgear GS108PEv3 on the network. There are no wired connections between the AP's, the satellite has a single wired connection to my desktop on one side of the house. The "router" AP has wired connections to the switch, steam link, a raspberry pi, storage server and printer.
