TomMcM
Jun 21, 2021Aspirant
Orbi satellite make clicking sounds
I recently installed a satellite orbi router to my system and it makes a sof clicking sound. The base unit does not. The satellite is hardwired to the ethernet network. Not sure how to eliminate t...
Jun 21, 2021Guru - Experienced User
question.
Are you sure its the satellite making the noises?
For some reason, my orbi satellite (and router) would make my subwoofer have a soft ticking/clicking noise.
I put my router/satellite on a seperate circuit and it went away. Only had issues with the 1 subwoofer doing it. None of my others. Tried several of them.
