TomMcM
Jun 21, 2021Aspirant
Orbi satellite make clicking sounds
I recently installed a satellite orbi router to my system and it makes a sof clicking sound. The base unit does not. The satellite is hardwired to the ethernet network. Not sure how to eliminate t...
TomMcM
Thanks for the response. Yes, it's Orbi. No subwoofer on system, and when I disconnected power from Orbi, clicking stopped. When plugged back in, no sounds as it went through reboot (light flashing), then started again once rebooted.
Thanks
Jun 21, 2021Guru - Experienced User
Tried swapping the power supplies? See if its coming from the power supply
- TomMcMJun 21, 2021Aspirant
I'll give it a shot. Have to wait until user(wife) gets off computer (home office for wife and I; separate businesses. AM not an IT type, so bumbling my way through troubleshooting problems. :smileyfrustrated:)
- xbrendaxSep 25, 2021Aspirant
Did this issue ever get resolved? I am having the exact same issue. Just installed this today and the AC adapters are making a clicking noise just as described. Tech support at Netgear is not helping resolve this. :/
- CrimpOnSep 25, 2021Guru - Experienced User
Clicking sound is not normal. I would ask for a product replacement.
