amd2100
Oct 14, 2020Aspirant
Orbi satellite not connecting with devices
My orbi satellite connect with my orbi router. But now my devices cannot connect with satellite. It's happen today. All the devices connect with my router not with orbi satellite. Is there any solutio...
Mstrbig
Oct 14, 2020Master
amd2100 wrote:
My orbi satellite connect with my orbi router. But now my devices cannot connect with satellite. It's happen today. All the devices connect with my router not with orbi satellite. Is there any solution to fix it. Satellite connect with my router without any problem. Installed latest updates.
Is there any way to remove my satellite and re add?
Are you sure nothing is connecting to the satellite, or is the app or GUI reporting wrong info, which happens, with the latest firmware update?
amd2100
yes I am sure. all my devices connect with router. not with my satellite .
- amd2100Oct 15, 2020Aspirant
this is how i can see it
Small update.
When i connect my pc to my orbi satellite thrur ethernet cable I can go online. but non of my wireless devices connect to orbi satellite. any solution? I have done all the other changes like resetting the two routers etc. but not working wifi.(orbi satellite rbs50)
