NiekG's avatar
NiekG
Follower
Apr 19, 2020
Orbi satellite not connencting with router properly
Hello, about a year ago we have purchased a orbi rbr50v2 including 2 satellites and a router.
For about a year it worked fine but right now the connection between the satellites and router is falling.
When activating a satellite and syncing them they connect based on the colors in the app. Sometimes they are purple, sometimes green and ever so often orange. But after a few minutes of being connected the internet stops working. On a laptop it says connected but no internet connection with a yellow triangle next to the wifi icon.
We have tried resetting, restarting, changing location but it doesn't work.
The router is connected via a cable in the wall, between the router and satellite is a distance of about 6 - 7 meters. The wall outlet next to the satellites is not occupied and they are standing up straight.
We don't know what else we can do to make sure we have a internet connection in house. Also the cabled internet isn't working either. It seems that there is just no internet coming from the satellites. When we are down staires and connected to the router instead of a satellite the internet does work.
I hope somebody knows a solution or has any suggestions.
Stay healthy,
Niek
  • CrimpOn's avatar
    CrimpOn
    I would be useful to know the firmware release on the router and satellites.
    Does the laptop function correctly when plugged directly into the router with an ethernet cable and over WiFi?
    (not using the satellite)
  • FURRYe38's avatar
    30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Stay healthy,
    Niek
