EdZz
Apr 18, 2020Guide
Orbi Satellite not syncing with Router
Hi all, i was hoping someone was able to give me some assistance, i've been plugging away for a couple of days with no luck. My Setup RBK50 Orbi (firmware version was 2.5.1.8 but downgraded to ...
CrimpOn
Apr 18, 2020Guru - Experienced User
EdZz wrote:
- Moved the satellite right next to the router and do the syncing process, no luck
When you "factory reset" both the router and satellite, and did a fresh setup, was the satellite "right next to" the router over WiFi or ethernet cable?
- EdZzApr 18, 2020Guide
When i did the factory reset, admittedly, they were in their original positions, 10meters away and i think it was wireless.
Furthermore, when both the router and satellite were fully booted, i plugged the ethernet cable in and i did the sync..
- CrimpOnApr 18, 2020Guru - Experienced User
I am no expert. However, I recall reading that many people recommend doing a WiFi sync of the satellite and router first, then connecting them with an ethernet cable, and then finally moving the satellite to its remote location.
I also agree that this is a crazy situation. I am a bit puzzed about what happened to the router when it was moved away temporarily.
Ok, i'll factory reset everything all via wifi and give it a shot... if wonder if well be at square one if it eventually does sync when both devices are right next to each other and then when i move back the satellite, the router doesn't sync with it again hrmm...
i'll give that a shot now and report.
cheers for the help :)
