Chris1984
Feb 26, 2019Tutor
ORBI Satellite not transmitting 2.4ghz
My Orbi satelite is not transmitting a 2.4ghz chanel and the closest devices are not connecting directly to it .
Feb 26, 2019Guru - Experienced User
Does it connect and synce to the Orib base?
Has a factory reset been performend then re-added to the base?
If so and the satellite isn't working, you'll need to contact NG Support and ask for an RMA.
