Chris1984
Feb 26, 2019Tutor
ORBI Satellite not transmitting 2.4ghz
My Orbi satelite is not transmitting a 2.4ghz chanel and the closest devices are not connecting directly to it .
Chuck_M
Feb 27, 2019Mentor
Log onto the satellite web gui (not the router) and tell us what the status screen says as far as the status of the satellite
Here is an example from mine
Budgeuk
Apr 15, 2019Aspirant
Mine shows 2.4 grayed out
- FURRYe38Apr 15, 2019Guru - Experienced User
Can you confirm that it's not transmitting with mobile app on a Android if you have one. Wifi Analyzer. This will show you if the radio is broadcasting or not.
If it's not, I recommend you get ahold of NG support and ask about an RMA>
