wairds
Mar 31, 2021Tutor
Orbi Satellite Offline
My setup is an RBR50 in access point mode with two RBS50 satellites. This morning I noticed one of the satellites was showing offline. I disconnected it from the network, switched it off and then ...
esteg
Mar 31, 2021Guide
wairds wrote:My setup is an RBR50 in access point mode with two RBS50 satellites.
This morning I noticed one of the satellites was showing offline. I disconnected it from the network, switched it off and then on in the hope it would reconnect. It did not. I tried this again observing the light ring at the top of the satellite. No light ring of any colour was showing. I then tried a factory reset using a paper clip and held the clip in for over a minute. The power led was showing green and continued to show green. The instructions indicated it should turn to amber. It did not.
I should add the other satellite works without a problem.
I strongly suspect the worst but would appreciate any advice.
Thanks in anticipation.
Actually there is a problem with new firmware. Dunno if it applies to AP mode (mine si in router mode) but try to uncheck TM (Traffic Management).
Regards.
wairds
Mar 31, 2021Tutor
Regards.
Thanks for your response however I think Traffic Management only works in router mode. The two satellites and the router are on firmware version 2.7.2.104.
