cblier16
Apr 14, 2020Aspirant
Orbi Satellite Options for RBR50
I have Orbi RBR50 and satellite included in my whole-home WiFi solution. Speeds are generally good, but I am looking to add another satellite to improve speed to another part of my home. How shou...
Apr 14, 2020Guru - Experienced User
If you have the 50 series system, it would be better to keep with the same series RBS. You can connect the other RBS models. Just know that the wireless back haul speed is 866Mbps and not 1733Mbps as with the 50 series system.
The 5Ghz front haul is the same for all models, 866Mbps.
The 2.4Ghz front haul is 400Mbps I believe on the 20/30 series.
- cblier16Apr 14, 2020Aspirant
Thank you for the quick response.
I have Netgear Nighthawk CM1150V modem, which I purchased to avoid renting from the cable provider. My home is 2,500 sq.ft., but spread over 4 floors. The current satellite is 2 floors above the router, probably 20-30 feet away, and it works pretty well, but I am looking to extend the service with a satellite to the floor below the router.
- FURRYe38Apr 14, 2020Guru - Experienced User
Kind of up to you. You might try a 20 series RBS out and see how it works for you. Or go with the 50 series RBS. Something to test out and see.
