pipiche38
Nov 18, 2019Aspirant
Orbi satellite pas d'adresse IP - RING LED Fushia (RBS50)
Voila, depuis pas mal de temps, j'essaie de connecter un Satellite ORBI RBS50 sur mon la base router RBR50, mais sans succès. Lorsque je démarre le RBR50, j'ai l'anneau qui clignote blanc, puis Blue ...
Nov 18, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
This is the Orbi forum for English users. For French users, please post here:
https://community.netgear.com/t5/Orbi/bd-p/fr-domestique-orbi
Good Luck.
- pipiche38Nov 18, 2019Aspirant
The ISP Modem is an Orange box (from the French ISP). It is only pluged wired to the ORBI Router and Wifi is disabled.
ORBI Router is set in : Router Mode
See attached a screenshot of the Orbi Router config, the Wireless settings was captured on the previous pose
The flat is about 130 m2
- FURRYe38Nov 18, 2019Guru - Experienced User
There is a router in front if your RBR. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- pipiche38Nov 18, 2019Aspirant
Thanks for your answer,
but I don't see the relation between not able to have a stable communication between ORBI Router and ORBI Satelitte, with the fact that I have double NAT!
There is not a single Wifi enable from the ISP router.
I'll have a look to setup the Orbi router in AP Mode in order to avoid the double NAT (good point), but still I do not see how it could impact Route <-> SATELITTE communication, or I missed something
