bpalob
Mar 30, 2021Tutor
Orbi Satellite permanently pinging the gateway
First of all, I am using the Orbi RBR750 system, which I didn´t find in the Model Listing for this forum. The FW in use is V3.2.16.22_1.4.9. I found a thread about the same issue, which seem...
Mar 30, 2021Guru - Experienced User
Please visit and post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- bpalobMar 30, 2021Tutor
Done. Thanks for the hint. Though I can also not find my model in the list there when posting ;-)
- FURRYe38Mar 30, 2021Guru - Experienced User
I tend to use this menu system for Orbi models:
https://community.netgear.com/t5/Mesh-WiFi-Systems/ct-p/home-orbi
Good luck.
