sohammistry95
Oct 20, 2018Star
Orbi Satellite poor backhaul Status
Hay guys I owned an RBK40 Orbi WiFi system. I was having little poor speed. After I power cycle the Orbi system and SP Modem, I see backhaul status of the mini satellite is Poor.
Would anyone coul...
JoeCymru
Oct 21, 2018Virtuoso
Just as another troubleshooting step, Advanced>Advanced Setup>Wireless Settings.. Enable Daisy Chain. Though this may seem counter intuitive, with the last firmware update some (myself for one) are experiencing poor backhaul with Daisy Chain disabled. I am not sure if this will help if you only have one satelite, but worth a try, since it is an easy change to try.
