sohammistry95
Oct 20, 2018Star
Orbi Satellite poor backhaul Status
Hay guys I owned an RBK40 Orbi WiFi system. I was having little poor speed. After I power cycle the Orbi system and SP Modem, I see backhaul status of the mini satellite is Poor.
Would anyone coul...
Oct 21, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Would anyone could assist me on why the Satellite is having Poor backhaul connection?
I just want to inform you that I haven't changed any settings on router or didn't moved the Orbi router or satellite to different location. So, I don't know why I'm seeing poor backhaul connection. Secondlly, I don't know how long this has been happening.
