Chucky_uk
Jul 31, 2018Follower
Orbi Satellite Problem
HI - I recently purchased the ORBI kit and have been very impressed but have noticed that the satellite randomly flashes white and then stops after a couple of minutes.
During the night this is very noticeable as I have the satellite within the master bedroom in my house. Why does the satellite do this and is there anything I can do to stop this from happening?
Also why do devices I have in my master bedroom not connect to the satellite but connect to the router? My firmware is running on the latest release. Any help or advice is appreciated.
1 Reply
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite? 30 feet is recommended in between them to begin with depending upon building materials.
What channels are you using? Auto? Try setting 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Beamforming, MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite.
